scarecrow
Outstanding in his field
i think this is my first tread in the mig section
I was doing a bit of practice today on some 2.5mm box with 1mm wire I can get it to weld okay but is always sounded a little poppy if you know what I mean so I thought maybe the wire was a bit heavy for the lower setting so i was just wondering is there a minimum current for a wire size
it sounded much better when you turned the welder up on heavier steel
when it was welding okay i changed the shroud back two the original one that came with the welder which is a good bit shorter than the new one because i cut off the burnt end and now is level with the tip
when I used this shroud is blew through and under cut on the same setting
so I'm wondering why the shroud makes such a difference to the power of a welder
tip, shroud...bungle...even the swan neck!
....than pay a lot of coffee to a maintenance lad to sort your little problem out!!
