Onthespotwelding
- Kent - England
not directly to the bottle!
I'm sure somebody somewhere has found a way...I don’t think that’s possible is it?![]()
Anything is possible if you try hard enough, or are stupid enough.............really depends on the person........I'm sure somebody somewhere has found a way...
Once you have connected it up, open the tap on the flow meter all the way then adjust the main regulator until the ball reaches the top of the gauge. Then set your required gas flow via the flow meter.
Because I'd expect his main regulator gauge reads in lpm, not bar (or psi)Why do you need to do that? It seems to be calibrated at 2 Bar (29psi) so just set the regulator to that.
Jack
OK, thanks. I would have used a pressure gauge.
I ask because I have not done that before and I wonder if it results in the correct calibration pressure for the flow meter. More likely it gives the maximum calibration pressure of the flow-gauge - that might be similar, but it might also be considerably higher.
Jack
Not really sure what that means - do you still have the tech-sheet? If you have a regulator-flow gauge followed by a flow meter, there is no inlet pressure reading - it is a flow reading.Said it was calibrated with an inlet pressure 10% over the maximum gauge reading.
