CompoSimmonite
100% positive that they are rod operated by a slave cylinder.A35 had hydraulic rear brakes spent many years working them
Seriously mental, if that's a 302 ci motor in there, which it looks as though it might be....Well, this one does, but then I think it's known as "A302" on account of the slightly larger-than-standard engine.
And midget bits are really plentiful. Marina1300 engines plentiful too...
I saw an Allegro 2 door advertised locally yeaterday, for a full 5 minutes I thought about it - Rover 2l 16V mechanicals etc...
Actually not that hard, yes some stuff is a PITA but it's the same/similar running gear as lots of other Austins of that eraThe biggest issue is just getting parts when something goes wrong.
The issue isn't that they are much more likely to break down compared to when new, it's just that decades ago when one broke down they could find a local business with suitable parts. Now if one breaks down the parts aren't available easily so the vehicle needs to be towed. I drive my mini 300km per week to and from work. Even with a mini, I have to rely on stocking parts myself. 1950s cars are much more difficult.
Were the ones you worked on 1960's firms A35 vans ? AFIAK the saloons never had hydraulic rear brakes as standard for the production run that ended in 1959.depends on the year
They used to be raced in the 50's and sight of them cornering on the door handles will stay with me forever.go ahead.......great idea.....
biggest headache is the SU fuel pump if it was fitted to that model....
the new fuel pumps from China work well and last...
on the rebuild I'm doing it will get 2 pumps side by side just in case...easy to swop wires n pipes....mine will end up a wedding car....
the other thing I've done is to get the dizzy modified to electronic ign....the copies of the good ol Lucas points are not that reliable.....plus on ur's it's down a deep hole.....
have ur fun, speed aint every thing.....
a lot of vans didn't A35 go onto the 60s wicki says 1968Were the ones you worked on 1960's firms A35 vans ? AFIAK the saloons never had hydraulic rear brakes as standard for the production run that ended in 1959.
Still are...They used to be raced in the 50's and sight of them cornering on the door handles will stay with me forever.
1968 was end of van production. Saloon, both two and four door, finished in 1959. Vans are now fetching the highest premium !a lot of vans didn't A35 go onto the 60s wicki says 1968
Marina 1300's engines are getting scarce. I've been after one for ages to replace the previous 1800TC in my Marlin Roadster.And midget bits are really plentiful. Marina1300 engines plentiful too...
Saw a bunch on ar**book the other day, cheap as chips - they are not scarce.Marina 1300's engines are getting scarce. I've been after one for ages to replace the previous 1800TC in my Marlin Roadster.
