Pete.
- Kent, UK
You have the fine feed working right, engaged by the right lever.
I think the lever on the left is to engage the power downfeed, and it should lock by some kind of ball-and-spring probably in either the in or out position.
The reason your quill drops is because I reckon the quill return spring has broken or become disengaged. It's possible someone had had it apart and left bits out or put it together wrong.
....but as you have found out an impact wrench is a great modern alternative.....
