Guy I'm working for has some Biomass Boilers fuelled by Firewood Furnaces.
Now first off know nothing much about them & haven't seen the complete things in service - but today he waved some old parts at me and basically told me....
There is a fan motor at the rear of the burner unit. This has what I'm told is a Single Phase IN & Single Phase OUT, Variable Frequency Driven Motor.
The VFD piggy-backs off the motor casing.
In turn the Furnaces unit has a main controller, which I'm told interacts & signals the VFD to alter speed ( for example if the furnace door is opened the fan speed automatically goes to max, the only time I'm told it does so).
Here's the thing.... the VFD's are fragile & go pop a lot, znd the OEM supplied replacements are £500 each
. Consequently another solution is being sought.
Questions:
1. Are 1ph - 1ph 230vac to 230vac VFD readily available affordably?
2. If no to 1 above, could a 1ph motor speed controller be used instead?
(Note owner is happy to have a manual speed control knob and dispense with the main controller issuing what I assume is an automated signal version of a manual potentiometer. The OE VFD has connections for 1ph+N+E in and out, plus a 3-pin connector which I think must be for the signal from the main controller to change speed - see pics).
Motor: 1ph 250 watt rated
VFD gubbins (note 3 pin connector bottom right on PCB, while on left top us power out, and power in is left bottom:
Sorry its so bit vague, but that's all I've got to go on atm!
TIA, G.
. Consequently another solution is being sought.Questions:
TIA, G.
