gerrymoore
CNC expert (well, getting there!)
- Wirral UK
I'm changing the OSF cv joint of swimbos 2015 Mazda 2.
Had a problem undoing the axle nut but managed with a 6 foot pipe and a LOT of pressure to undo it. Finally got the cv joint pushed out of the hub and then... can';t get it off the driveshaft. Spent over an hour trying just about everything but it will not budge. I'm assuming that the circlip is jammed somehow cos I have hit it VERY hard but it won't budge. The only idea I have is to take the whole axle out and get it in the vice and maybe have more luck but car is on a jack and it's an automatic gearbox. Will I be OK just pulling the whole shaft out or will I need some sort of tool to lever it out of the box? Also will I lose transmission fluid in the process? Or does anyone have a better idea to get this darned CV off ?
Thanks guys...........
