unless u can pick something up second hand. il post later im getting some info on the 415v digitalHello Langy,
try this company for advice, I've found them helpful in the past, and they do 240 v single to 415 v three phase units.
http://www.drivesdirect.co.uk/index.htm
Alec
Make your own rotary. Mine would drive that and it cost less than £200
using all new parts inc transformer.
Thanks guys, I think i will leave it
If you decide not to have it I would be interested, a mates compressor has just gone pop and he needs a good one soon as.
Thankyou, thats great, I'll give you a call in the morning. Do you know if it could be loaded onto a pallet so I can have it picked up ?
Tell me more now you have my interest![]()
Rotary converters are pretty simple, look up rotary converters and you will find lot's of yank sites[ fitch williams's ramblings/designs seem pretty sound]. Basically I made the same as his converters. Using 415V means you only need a fraction of the capacitance they talk about . I have a 240 to 415V transformer at the input to the converter, that's the only way mine differs really. oh and spetics use a potential switch to switch the caps, which can easily be done with a few electronics components[they are the bit's on the
terminal block on the left hand side wall of the box].
I wired the garage and shed from the converter so I turn the converter on and the machines work on their original switches and stuff.
Image below is the inside of the box on the wall, the motor, transformer and one lot of run capacitors are in a box on the floor. The caps in the image are the start caps and run caps which are switched automatically when you switch it on. It's been in use since 2003, I will get round to finishing it one day;-)
If you want to have a go I can give you a pdf wiring diagram, I didn't actually do a diagram while I was building mine, I drew it for someone some time after I made mine. I just laid the bit's out on a bench and experimented a bit till I had a balanced voltage under load. It should be fine running 10hp all day long's but was tuned with a 3hp lathe taking a heavy cut.
Did you get it ???
