That Cavalier is up for sale mate - have you seen it? £120k... Cheap for a bit of BTCC history.Looks good to me! dont mind the colour combination either
I just don't want to start sanding paint off it I can help it. At least it isn't a car, and it is very curvy so there aren't lots of flat panels. I reckon there's only a few square feet that would need polishing that are really visible. But curvy panels are easy to burn through with a polisher - I'm not brave enough.I think you are supposed to wet sand it next and polish but it looks a frightened process to me.
Knock back the peel with the finest grade that will do the job. 1500 is a good starting option. You are looking for a uniformly flat, matt surface free of imperfections. Then change the water and go up a grade or two until you get to around 3000. At that point you should be able to use a compound and mop to restore a deep g
Cross posts. Can I hand polish it up afterwards as well?Cheers AJ. My worry is that the areas on the front of the legshields are curved and probably one square foot each, and the same with the side panels - lots of curves and edges. My polisher is 125mm disc and I'd struggle to move it around much. Scary - I think I winged it on the painting and got away with it but could ruin it quite easily. How much could I do just by hand?
