i better explain what i want i suppose, i have a field in the middle of nowhere there are 3 buildings there i spend a lot of time there in the summer not so much in the winter, i would like to convert one of the buildings to a workshop and spend more time thee now ive retired and youve guessed it no mains power
i did get a quote from western power distribution a rather eye watering £44,000 just to get to the corner of the site and then on top of that more for poles to bring the power down to the buildings and then on top of that there will be a standing charge and on going bills, thats just not going to happen, several years ago i bought 4 cheap 100w solar panels off ebay and wanged them up on the roof cheap charge controller and a few car batteries and it was enough to run the cameras internet and led lights, this later escalated into 20 240w panels bought from a solar farm that was upgrading to 480w panels, followed by victron charge controller and inverter and 16 120A leisure batteries connected series/parallel to give me a 24v system for the batteries, now all the solar stuff works just fine for the moment its easy to produce enough to fill the batteries in the summer months the winter is a different story but as i wasent there much it dident really matter much, however times are changing and i want a workshop there with workshop tools,
so my needs are 2 fold and im guessing you are going to say i need 2 different generators, first i need to power the workshop but that only needs power when im actually using a machine be it car ramps or welder, grinder what ever and i assume i will only ever be using one tool at a time as im not clever enough to use the welder while pressing the up button on the car ramps, i can run led lights in the workshop from the solar system so some days i wont even need the generator probably several days a week it might not be needed, so the first question how big do i need some of you have generator power for workshops ? ive always belived in bigger is better but i guess i dont need to be running a perkins V8 diesel just to used the bench grinder
and the second requirement is charging the 24v battery system in the winter months for maybe an hour a day again i dont needs to be running a 6 cylinder diesel just to do that, i was thinking of a single cylinder lister or such like running a lorry 24v alternator just to top up the batteries as and when required, i have 2 spare shipping containers that i can utilize one can house the generators and the other a thousand gallons of diesel and i can be independent, ok that might add up to nearly ten grand but its only a quarter of what weston power wanted for me to be shackled to the grid for ever, actually it might be less that a fifth, i wonder how long a thousand gallons will last on an infrequent basis , there is a wood there to so log burner in the work shop me thinks, so how big a generator should i be shopping for ?
i did get a quote from western power distribution a rather eye watering £44,000 just to get to the corner of the site and then on top of that more for poles to bring the power down to the buildings and then on top of that there will be a standing charge and on going bills, thats just not going to happen, several years ago i bought 4 cheap 100w solar panels off ebay and wanged them up on the roof cheap charge controller and a few car batteries and it was enough to run the cameras internet and led lights, this later escalated into 20 240w panels bought from a solar farm that was upgrading to 480w panels, followed by victron charge controller and inverter and 16 120A leisure batteries connected series/parallel to give me a 24v system for the batteries, now all the solar stuff works just fine for the moment its easy to produce enough to fill the batteries in the summer months the winter is a different story but as i wasent there much it dident really matter much, however times are changing and i want a workshop there with workshop tools,so my needs are 2 fold and im guessing you are going to say i need 2 different generators, first i need to power the workshop but that only needs power when im actually using a machine be it car ramps or welder, grinder what ever and i assume i will only ever be using one tool at a time as im not clever enough to use the welder while pressing the up button on the car ramps, i can run led lights in the workshop from the solar system so some days i wont even need the generator probably several days a week it might not be needed, so the first question how big do i need some of you have generator power for workshops ? ive always belived in bigger is better but i guess i dont need to be running a perkins V8 diesel just to used the bench grinder
