Jelly_Sheffield
Time is an illusion. Lunchtime doubly so.
- Sheffield, UK
It depends which one you choose, the cheapest models available from eBay/Amazon/AliExpress often come needing at least some of the parameters setting, and with awful documentation.VFD's are a piece of ****, not sure what would require a professional, specialist or tech support.
In the case of the car lift:
- buying a 1~240V to 3~440v VFD from a reputable manufacturer/modifier and wiring it in would work out the box (at home, exposed VFD as the controls absolutely not PUWER compliant),
- using a 1~240 to 3~240 and swapping the motor to delta is marginally more complex,
- wiring the existing controls back to the VFD and setting the parameters, might flummox some people at first but with a bit of reading it's all learnable, although if you can just ring up the seller and ask for the correct details it's a lot easier.
When I was suggesting tech support, I was responding to a poster with quite a few different machines who was finding understanding the issues with 3-Phase hard going.
Not knowing what they had exactly, advising them to buy VFD's from someone who could help them select appropriately seemed sensible.
There's definitely pitfalls with VFD's on more complex machine tools, depending on what you're retrofitting your ability with wiring/re-designing control panels, and when taking about multi-motor machines, understanding of the limitations of VFD's with respect to on-load switching come into play.
Nothing too difficult, but the first time you do one, it would be easy to lose a lot of functionality (or even blow up a VFD) if you misunderstood...
I'm that situation, for a beginner it's well worth buying a slightly more expensive VFD from a company with a good tech-sales guy to guide you, totally worth it IMO.
All bar one of my 3ph machines would need an extensive re-wire, and 3 would need more than 1 VFD to still work properly after conversion, so I didn't bother going that route...
Had I bought a less complex lathe when starting out, I may not have committed to the RPC and Genny.
