Chains are actually quite efficient. Whether that is true in this orientation is another matter. In any case it will be better than the lock up with badly printed gears (think my X and y axis are calibrated slightly differently!Gosh. Friction surely? So much friction!
But every iteration has more shafts and bearings. It's not so much the chain I was referring to. I know nothing so its just my ignorant viewpoint.Chains are actually quite efficient. Whether that is true in this orientation is another matter. In any case it will be better than the lock up with badly printed gears (think my X and y axis are calibrated slightly differently!
Is that what you’ve made or a render?So here is Mk-7. I'm waiting for a couple of SKF 635 bearings. Meanwhile I'm printing bits to do fit testing. The chain links have come out nice and with a bit of cleaning up I have a nice slinky chain. I hope it will work ok in a horizontal orientation. I've modified the links today to allow space for HDPE washers, which make great bearing surfaces for PLA. Gotta find some punches to make washers or fix my friend's laser engraver to cut them out.
It's a render of the CAD model using Blender's Cycles render engine in FreeCAD.Is that what you’ve made or a render?
No, you're right, @Guineafowl, it would be much more practical to do a simple proof-of--concept but the project has kinda evolved over time and the initial experiments I did convinced me that the principle is sound. Realising it in practice with 3D printed parts (especially given the printer I'm using, though for today's test prints I've upped the quality by dropping the layer height from 0.3 to 0.2mm and it looks like the quality has improved immensely, though print time has consequently expanded considerably).That’s elaborate.
I was expecting you to build a much simpler proof-of-principle machine first. Maybe one fixed magnet, one attached to a pivot so it can lift an adjustable weight up and down as the gate is moved in and out of the field.
Is it too late to say that? Yes, much too late. Sorry.![]()
It will take off like a runaway diesel engine.
Yeah, there may still be a few minor wrinkles to iron out.You realise that once you start it you'll never be able to turn it off?
