Rotary Transwaves are good kit. The pilot motor removes the need for selector switches and no worries about small motor burn-out (so handy for kit that might have 0.75hp feeder motors or such that need to work without the main motor in use). The weird ph-ph voltages you get on statics aren't as weird too.Tom,
it all sounds very simple by the experienced memembers but I think it's a black art.....
I'm in the same boat as u and am really considering VFD for my 3 phase gear.....
BUT everytime u read something u find out something else either good or bad.....
above, someone says a static converter is not so good on high loads on motor start up....i.e 2 post car lift.......mines 3hp x 3 phase.....
I'd thought about a rotary unit but it all seems so complicated esp as I have nobody to help build such a thing...even happy to pay good money to get the job done.........
so a bought unit from Transwave /plug n play seemed good until reading the above....so again, now undecided...and I cant afford to pay £1500 for something that may not do the job.....all other machines are lathes, mills or wood saws etc.....again all about 3HP x 3 phase....
so far it very important to know how much power u have comming out of the fuse board / supply......I think mine is 40amp x 240v.....not at home to find out for u....
this will determin what u can ex[ect from ur VFD / rotary supply....others here will tell u more....again this is a black art.....
In my prev workshop I had 3 phase....read until the end....
BUT my 2 poster Hoffman car lift struggled lifting the heavy 4x4's and small tractors MF 135's etc.....my prob was not the power supply but the lift speed of the ramp.....
will inc photo of my mod.....with the gearing = 3 narrow belts the drive pulley on the motor was basically doing all the work on 1/3 of it's diameter.....
it used to eat belts.....asked Hoffman, now gone bump if they could supply a bigger pulley for the lifting screwed shaft.....that was a laugh....
so made my own as an experiment.....it worked just fine and is now 12 years old with no probs.....
the shaft pulley is around 25-30% bigger dia than the orig, slowing the lift speed down, hence less strain on the motor/electrics.....it's made from aheavily glued up plywood sandwich....thinking that if it works I'll make a new pulley from Nylon....not gonna bother now.....also u'll notice that the belts, NOW Kevlar are arranged so they rotate about an aditional pulley .....well a stack of bearings on a heavy bolt.....
this now makes the belt run nearly 50% of the drive pulley surface......the Kevlar belts * notched* will take this reverse bending easily .....
going from a set of replacement orig belts every 3-4 months, now 3-4 years....
So even if ur slightly underpowered changing the gearing will help a lot....
ps, now have a new belt guard and a better job of the bolt/ studding....it looks a bit Heath Robinson but it works.....
those are not Kevlar belts but originals....didnt want to spend any money until I was sure it all worked....
You always want any motor start circuits on a pH conv to be on L1, not L2 or L3, as this is the phase that should be at "mains" voltage.
The big thing to be aware of is that a pH conv can only convert the supply it gets.... so if you put rubbish in, you'll get amplified rubbish out. So a poor utility supply (or a poor local feed to it by the installer) will be time for it to start playing the Mission Impossible tune.
Again - when I dealt with them Transwave were a mine of useful info on what is a black art - there are few scenarios and loafs that they haven't come across (& they are keen to support their product & show its not their kit that's the problem, but either an incorrect product selection for the task, or some other - so you'd get useful troubleshooting help IME).
Case in point - a mate contacted me years ago about one, and advice from TW was a 7.5hp Rotary (for a variety of old woodworking machinery used one at a time).
Mate baulked at the extra cost, and because of his nature - bought the static instead.
Then.... rang me moaning that the unit was junk. I had a look, & found that he'd hooked the (not as advised static) Conv up on a manky bit of old household 2.5mm T&E cable to start with, and the 3ph machine he'd connected had seized rollers meaning the start-up power needed was ridiculous..... yet it was the Conv that was "junk" & not his bad decision & worse botchery!
Once connected properly & to a serviceable machine, the Conv proved to be just fine (unsurprisingly).
