DAPPH
as dyslexik as I'm daft
Help , I need a bit of advice .
Several of you engineers also engineer in wood or at least bother it somewhat . I have seven second hand internal doors to fit most have bee cut to size and the off cuts will be glued & screwed to two of them to make a wider wheelchair accessible door
Who ever put the replacement doors inthis place over 23 years ago must have used a treacle ruler for no two hinges are the same distance on the doors at the top , same witht e botoms . I'm happy to route out the old hinge positions fill screw holes with glued in pegs and insert a glued in wooden blanking strip on all frames and doors .
Question what is a reasonable distance from top of door to the top of the hinge for it and also the same for the bottom of the door ,,how high is a hinge normally set from the bottom of the door to the bottom of the hinge ?
Just to amuse you the shortest distance to the top of the top hinge varies between 6 " to 14 &1/4" bottom hinges are 5 to 18 " from the bottom of the doors to the bottom of the hinges .
Thinking of fitting three hinges per door ( Ironmongery direct ) , so over time they will not warp to much in high humidity associated with warmer years we are supposed to be heading towards .
hopefully ) ordered 11 pair of Chinese bearing'ed internal door hinges 100mm high x 75mm when opened flat so there are three hinges per door .
