Well not quite, but close.
I have a need for a punch and die - 6mm x 1.5mm. I managed to buy one , but the die was physically to wide for the part I needed to punch through.
So I need to make a new bottom die - 6mm x 1.5 mm with perfectly square corners.
I have my new milling machine (Hooray) and a 1.5mm cutter (This is going brilliantly!) and I now have a nice slot 1.5mm wide, and 6mm long, with the cutter radius each end.
But I have a square ended punch.
How do I make the corners of my new die square. I presume I need to file them with a really thin file?or is there an easier/better way?
Are files less than 1.5 mm thick available (I've seen something about Escapement files?)
Alternatively - do I make a punch with the same radius ends as my new hole - as the square punch ends might be easier to file round.
Thoughts please - I don't want to reinvent a wheel if there's already one out there....
