Hi,
I made a diesel fuel pipe from OD 10mm / ID 9mm stainless pipe and I can't figure out how could I get some sort of bead done to it to hold hoses. I chose to use very thing tube just for the reason it would be easy to form the bead, but haven't yet come into any good solution. I tested on a piece of pipe, a tool that I made which does make flare, but that will definitely cut the rubber hose when inserted. Made also tool with internal chamfer and was hoping that it could bend the edge inwards after flaring, but it didn't work at all. Most likely it would need to be roll formed to work. Any suggestions, how to make beads to this or some other way of preventing the hose from slipping off? Or would hoses stay there with hose clamps (Norma Cobra) without beads when installed on low pressure side of diesel engine?
Thank you.
Thank you.
