ajlelectronics
- Gloucester, England
Doing it's job with temporary software...
That does look good
So my questions are, how to get the rear panel cutout and linked to the module case's lateral position?
The D type component I tried to use as a cutting tool, but whatever I did, the component became embedded?
Could you elucidate on the D plug please? I thought that I could use it as a "punch" but I could only merge it with the panel, rather than cut it away using the shell of the D plug which I though that I could do.
Keep your head about you, to just exactly where your working (the base model, not the assembly).
Like this - you can see the spiral path that generated the pattern...I would probably use a spiral and pattern the holes along that.
Use the coil tool - in will create a solid helix/coil using the optionshow do you draw a spiral in 360 ?
easy when you know howUse the coil tool - in will create a solid helix/coil using the options
