Paulbarrett
- Northampton
then a rigid theoretically self adhesive carbon fiber bandage, which has to be wrapped onto the aluminium patch .
No-one told me this .All the ones I have seen need the bandage soaked in water before use.
Here the instructions.
I'm kinda thinking it was expired or damaged.
Cause I'm serious it was like wrapping a coil spring
I wasn't suggesting that you were wrong, it is just my experience that they needed to be wet before they would conform. Clearly there are different brands and I have never seen one with 'Carbon fibre".
This one was bone dry .I remember using similar 40 odd years ago. You ended up with hands covered in sticky goo. Rather like when using Denso tape.
You GIT.Denso tape.
Denso! I still have bad dreams about that stuff. Used it on GPO (BT) to protect lead cables if jointing chambers required demolishing & rebuilding. Yuk. It was bad enough putting it on, removing later was horrible. It was always referred to as Gas Tape.I remember using similar 40 odd years ago. You ended up with hands covered in sticky goo. Rather like when using Denso tape.
what do you do when it dries oot? just replace it?Still use Denso all the time for covering hydraulic spool valves and hose ends on the fishing boats. messy stuff but it works great![]()
The top couple of layers dry out but it tends to stay good underneath and is still messy to remove years later.what do you do when it dries oot? just replace it?
Huh, tell me about it. Me, and all the other unlucky gubbers who had to hack the old shyt off to repair joints.The top couple of layers dry out but it tends to stay good underneath and is still messy to remove years later.
