Carterkelly32
New Member
- United States
I have a millermatic 215 that I’m using gasless. I’m welding mild steel to galvanized metal studs and lately I’ve been running into the issue of my wire getting stuck in the tip. I’m using .03 wire and tip. What seems to be happening is that before the wire goes through the tip, it is turning black and getting small bubbles on it as if it’s getting hot. I’ve checked everything I can think of including changing tips, replacing the liner, changing wire speed, volts, and loosening/tightening the rollers, moving further away when I am welding, however nothing seems to work. Does anyone know what is causing this??
