Unfortunately not. I have been opening things up to see if I can get a couple of screws but no luck then I stumbled across this forum which is really amazingHave you got an old mobile phone or something stashed away in a drawer?
Usually a good selection of small sizes inside obsolete tech
It would be better if it was cross head but it could workWould slot head do , if so I will check , I did have some as I was an optical tech.
Thanks so muchIt would be better if it was cross head but it could work
Can you PM me please. ThanksWould slot head do , if so I will check , I did have some as I was an optical tech.
Please can you PM me. Thanks so muchM1.4 definitely exist, we use them in a product at work. If you only need a few, PM me an address and I'll put them in the post.
They are for inside a laptop. That secures a side board to the case. The screws are tiny.Could they be 11BA? 1.5mm nominal diameter.
What are they for?
Not sure what screws they are but one supplier has said they are m1.5 and 2.33mm long.They are for inside a laptop. That secures a side board to the case. The screws are tiny.
Who knows. Wish the manufacturer could make this information available. I got some used ones from ebay and they came all strippedProbably are as you say then. May have been BA in some old British thing but probably not a laptop! Still, if you can find 11BA, they may fit(ish)
Yep. They are really small. I need a flash light to put them in. It makes no sense why to use such small screws when it is hidden awayId need a optician before I could see them
Can't you just whack a self tapper in the hole? Doesn't sound like it's anything critical.They are for inside a laptop. That secures a side board to the case. The screws are tiny.
I was thinking that myself, are they so critical that a piece of duct tape or a dab of adhesive of some sort wouldn't hold the item in placeCan't you just whack a self tapper in the hole? Doesn't sound like it's anything critical.
I would have liked to do this but the screw goes through a plate and then secures to the side of the caseCan't you just whack a self tapper in the hole? Doesn't sound like it's anything critical.
500/ 200/ 100pcs M1 M1.2 M1.4 M1.5 M1.6 M1.7 M2 M2.3 M2.6 PB Pan Head Black Electronic Micro Screws Phillips Self-tapping Screw - AliExpress 13
Smarter Shopping, Better Living! Aliexpress.coma.aliexpress.com
I can't put adhesive because it. Covers the leds on the pcb board on the plate. Duct tape won't keep it secureI was thinking that myself, are they so critical that a piece of duct tape or a dab of adhesive of some sort wouldn't hold the item in place![]()
When a screw drops out of your only pair of specs when on site in the US - buy a repair kit in Walmart, take specs off to to repair . . . discover you can't see the screw, never mind fit it .. .Id need a optician before I could see them
Thanks so much. That's really kind of you.I’ve got a tub of tiny screws from video cameras. If I remember, I’ll dig it out tomorrow and see if anything will do you
