Steviestevo
New Member
- Uk
Hi all,
So I'm doing a one off project that will see me have to cut some 20mm thick aluminium plate. I have a plasma cutter but that isn't powerful enough to go all the way through, and I've read you need a special disc to cut aluminium with an angle grinder safely. I really want to get this done over the weekend and can't find anywhere that does aluminium cutting discs suitable for my angle grinder in a reasonable driving distance from where I live - and to be honest, don't really want to use an angle grinder, given I'm not all that accurate with one!
The only other tool I seem to have that might be suitable is a vertical bandsaw, but its a cheap Screwfix woodworking bandsaw I bought for a restoration project before covid. I've read that aluminum can be cut in a woodworking bandsaw, but am not sure if such a thick plate would likely just end up stripping the teeth or destroying the machine. Any advice?
Thanks!
Thanks!
