You can only test what you can see .1998 diesel car without an EGR valve. Changed engine to a 2001 model with EGR valve blanked off. MOT pass or fail?
If the data plate is missing or illegible you test to the default value for the year of manufacture .You will normally see a little data plate on the slam panel, on that there will be a code like 1.8 or 0.9, there are many different values, that is the emissions value the vehicle year/type was approved to. so they will test to that.
you do see them tampered with, that is an instant fail.
https://movingon.blog.gov.uk/2021/12/08/emissions-value-tampering-on-the-manufacturers-plate/
Yes they do....
Land rovers don't display a plate for some reason
. I'm making some stainless plates to blank off the valve, whilst leaving everything still in situ, as don't fancy cleaning it out again if I can avoid it because such a nasty / dirty job !
