Welding.farm
New Member
- Uk
Hi all
I was given a Pickhill Bantam 180 that had been abused it is not clear what the person did but the negative work lead was all melted and the power feed in lead had a small bit of damage.
I suspect he may have shorter the output.
I have rewired a new mains lead on to it to test it on a single phase 230v supply but it keeps tripping the circuit breaker which is 32ah but I am just powering it off the normal ring using a 13ah plug which it had not blown.
I have removed it from the oil to look and nothing looks to have blown inside.
I have checked the resistance using a multi meter and it comes out at 0.2 ohms but I dont have anything to compare this to.
Does anyone have any ideas?
Thanks in advance
Thanks in advance
might do one day
if it was knacked it would take the rcd out on earth fault if its shorting down to earth . change the breaker . mine somtimes pops the 13 amp fuse so i overcame that
the welder is supposed to be fed from a 32 amp supply but will run on less unless constantly used
