Gazz292
- Scarborough
Not sure exactly where to post this, so thought i'd try here.
i finally have a small space to set my welder up permanently, and i'd like to get a welding fixture table 'kit'. one of those with the holes in it for clamps and 'fixtures', with side 'skirts' to clamp metal to that i want to weld at 90 degrees etc.
Something like this... it would be fixed to 1 meter tall legs with braked castors on them :
The size of the table i'd like would be 750mm deep, by 1500mm wide, with 2 or 3 'hole tall' side skirts... the holes being on whatever is the standard centres used for these types of tables (can you tell i don't really know much about fixture tables)
it would only be used for hobby use, welding things up for myself,
so it doesn't need to be cut from very thick steel, 6mm at the most?, maybe 4 or 5mm would be better?
It would comprise of a top, side skirts and then stiffener pieces that slot into tabs in the sides and top, and some plates to bolt legs to the underside of the table,
Basically a laser or plasma cut kit of parts that i can weld together to make the table.
As this is for hobby use, cost is a bit of a factor, and the reason why i don't just buy a 'kit' from people who advertise them,
I was wondering if someone on here with a laser or plasma table would be able to supply the steel and cut it for a reasonable price.
I know it would be a heavy thing, so pallet delivery would have to be arranged, i live near Scarborough, and can travel say a 100 or so mile radius to collect.
