Cato
- Birmingham, UK
I'm not sure where this questions fits, so if there's a more appropriate section my apologies for not putting it there.
It seems to be the case that if you need to make a long bolt taking a length of bar, turning a thread of an inch or two at one end and then welding a nut to the other is a common approach. The weld on/around the nut is then neatened on the lathe. Presumably this avoids faff on the lathe with turning hex bar a bit at a time, spring cuts etc.
My question is, does welding the nut on affect the strength of the EN24 or whatever at the point it's welded? Given that it's a fairly common approach it would appear that if it does it's not enough to cause a problem or worry about. On the other hand being a common technique doesn't mean it's the right way.
