Yeah, that is my photo and mine *doesn't* have a V cut in it. It's a solid block...And finally here's someone else's photo of under the saddle of a slightly different one than that diagram. It has a combined wear strip + locking plate, with a V cut in the middle of the plate to let it flex.
Ive been in the saddle a few times, its not too much grief to take it off if you take the right hand end of the leadscrews off, then slide the screws to the right (provided you have room!) then the apron comes out downwards when you release it irrc but its been a few years now. Doubleboost's videos above are worth watching because the 11" and L5a are pretty close. My Harrison is a bit ship of thesus now, it was originally a 3 speed leadscrew with threaded 2.25" nose chuck but now has a 11" norton box with modified leadscrews, a L00 spindle and all sorts of other mods. You have to keep improving things right...
I had a really old L5 originally and when I took the wear strips off, they had big wedges wore into them which allowed the saddle to lift, so it can be educational to look at these if you have the sensation that the saddle lifts under heavy load.
It also did absolutely nothing. My theory is that it worked when brand new but was marginal even then. Mine is however a very very old 1940's L5.
To make it somewhat more effectual I took a chunk out with the mill (so it looks more like the exploded diagram of the later models), it's still not great (might need a slit in it to work better) but it does at least work.
