waddycall
- Cornwall
Hacksaw and tidy up with a file. If there is a radius in the V’s just drill a hole of the right diameter to give the radius and cut up to that. Clean up with a file. You can rotate the blade on a hacksaw by 90 degrees so it doesn’t struggle with the length of cut. Just make sure you have decent blades. Not sure how many Tpi but someone here will know. Do it a bit at a time and keep in mind that it’ll be quicker than researching machinery and getting quotes etc for getting it outsourced.
. Does it need to be bang on 19mm and does it need to be all one piece or could you stack a few profiles to make up the thickness? The problem you are having with outsourcing the cutting may be related to suppliers needing to buy a full plate to cut it from. If it was a common thickness stacked it would probably be cheaper and easier.
