henry Kadzielski
- Australia Wollongong
No perfect
I was running at 110psi - is that a bit too high?
) can we use the small compressorwith suitable traps & filters and an air mask etc. to wear in the blasting area , the filters on my mask are stuffed.Smaller parts will be done it my big blast cabinet. It is about 4'x3'x4' internally.Hey Fizzy if you are thinking of blasting the lathe bits get a portable car shelter to set up outside .. sweeping up 600 or so square metres of used medium after each emptying of the pot was blinking hard work.
Thinking also ( my left foot hurts![]()
Try a shop vac.Hey Fizzy if you are thinking of blasting the lathe bits get a portable car shelter to set up outside .. sweeping up 600 or so square metres of used medium after each emptying of the pot was blinking hard work.
My nice big compressor kept up fine with a 3mm nozzle - mind you it was probably 6mm by the time we had finishedNot at all.
It works even better but if you can't maintain pressure it's better to go low for consistency.
As has been said the best mod is the proper media valve. It transforms those cheap blast pots.
I have a nice big one - but the stuff went EVERYWHERETry a shop vac.
So put up the tarp garage as your friend indicated, and you'll be able to pick it up much faster with the shop vac.I have a nice big one - but the stuff went EVERYWHERE
Might make sense to have a double arrangement - blow and suck at the same time![]()
