mangocrazy
Italian V-twin nutjob
- Sheffield, UK
The tubes are mounted on the roof and have 15mm copper flow and return pipes back to the DHW cylinder. The 12V DC pump (driven by a small solar panel) is on the return leg right by the collector. The DHW cylinder has two internal indirect coils, one for solar thermal, one for the wood burner (when I finally get it installed). It's as simple a system as I can make it, and their is nothing peculiar about it. The issue I am having is that the solar-powered pump is waking up early and pumping the water in the collector that has cooled down overnight and is cooling (rather than heating) the water in the DHW cylinder. At around midday the tubes start heating the water in the collector and the temperature in the cylinder starts to climb again, but from a lower base than is desirable.
As a very low-tech solution I've made a box to fit over the solar panel once the sun has gone down which will stop all pump activity until such tme as I take it off.
When I fitted the solar panel cover tonight the cylinder temperature was 50 deg C. I'll check in the morning and see what we have then.
