You can get Al-ox paper (aluminium oxide) in all the necessary grades and it doesn't clog as quickly when used dry. I have up to 3000 in the shed but really 80 to 2000 is as fine as I use regularly.
Yes there is. Mirka Abranet sanding strips or auto net disks also you can get rolls off production paper and cut to any size
local paint suppliers will be cheapest as for example, tub of easy one filler in halfrauds is around £25 and off a supplier £12 big big difference
, I can't get wet & dry more than 1500 there
If only, I can't get wet & dry more than 1500 there
try ebay mate!
If you really want fine grades you should look at micro mesh abrasives. You will pay quite a bit compared to papers but they last a lot longer and can be used wet and dry then washed and used repeatedly. They start at 1500 and go through to 12,000.
