Rannsachair
- Lochgilphead, Argyll, Republic of Scotland
Arrived today, claimed 3000 A
Got a noco gb70 here. Used many times on motorbikes, cars, vans, tractor and 7.5t horse box. Think it's 2000A and was about £160 3 or 4 years ago. Cheaper ones were available but it's lasted really well and I've been very happy with it. Those 4000A gooloos look very good and with twice the capacity than mine, which will start a 6l diesel, and only £100, seem like a great buy!
That lidi gadget doesn't look like it would be much use on anything other than a small car, for £100 ish you can get a 4000amp Titan gooloo, this thing will spin over the big tractors and plant.
Currently £10 voucher brings it to £80 so I am tempted.
Really surprised me, the lads ripped the fuel line off the telehandler and then proceeded to crank it over until the battery was flat, I reconnected the fuel line and had to bleed it up using just that Gooloo, couldnt believe it did it.
Bob
It failedI picked up a 600A at Screwfix last year, not used it in anger yet but I'm expecting to need it when I go to get my classic out of storage.
The one I got has built in LED torch and USB charger, handy when I'm working in the lockup with no power.
Battery Booster Packs | Car Battery Care | Screwfix
Buy Battery Booster Packs at Screwfix.com. Give instant charge to flat car batteries. Get moving quickly and avoid costly breakdown charges. Free returns.www.screwfix.com
Does it charge if plugged in? Or completely dead? Easy return though..
Reminds me I must give mine a proper test!
I charged my Gooloo 4000A on 19th January. 20th Jan I started my Discovery 2 TD5 which had a totally flat battery. Yesterday I started my propane Hyster Fork Lift Truck - again totally flat battery - the Gooloo is still showing 100% charged.Don't know, he put it on charge last night. Not seen him since.
I suspect it is faulty. Didn't it have the same problem with the good big battery we tried?It failed
After reading the manual I now know it has 2 safety features, an alarm if you connect the terminals the wrong way (great) also a warning that the car battery is scrap if the voltage falls too low
The car has been parked for a couple if months with the battery disconnected and hooked up to a dashboard solar charger. Voltage was 12 volts before I tried to start the car, it turned over but didn't fire.
The booster pack helped 1 time then declared the battery scrap. The battery was still over 11 volts and turning the engine over.
It's designed not to work at exactly the time you need it most. It's going back to Screwfix this week
I'd advise avoid Ring 600A link https://www.screwfix.com/p/ring-rppl300-600a-li-ion-jump-starter-type-a-usb-charger/389gy
Update: it didn't get returned and has worked fine a couple of times since.It failed
@dobbslc @fizzy @Kram
A good review but I only lasted about 11 minutes before I had to switch him off
Really good test on these if you can tolerate his voice
Noca the ultimate
Gooloo close behind.
Best value was the Yesper.
