Could you use an epoxy adhesive? It would probably look nicer than panel pins.Where do I get solid brass / copper tacks or panel pins...tomorrow and local?
Copper roofing nails? From your local builder's merchant.Where do I get solid brass / copper tacks or panel pins...tomorrow and local?
^^ Hope it's all appreciated!![]()
You'll be doing those windows next?
Not trying to cause an argument. But as the pub is a business. Are you getting paid for all of this work?
3D print trumpets to sit in the holes adding a further bead of silicone . Trumpets can have a mesh printed into the bell end , 3/4 inch max dia of the tube as there will rarely ever bee a lot of excess water in the planters that requires heavy drainage. The moisture route out also takes in fresh oxygen this in turn feeds bacteria which eats dead plant lmattrer and produces nutrients for the flowers ( Humus ) .@DAPPH ? One for you maybe. I was thinking to drill some holes in the base then run round them with a router to radius or chanfer them. Then whack a bead of mastic around each and line with the dpm. When stuck puncture where the the holes are. Not sure on how many holes / what diameter. Or even whether to V the base in two pieces slightly like a keel.
Feeding the planters with neat rabbit poop and raking it in the top 35 mm then watering then planters s a good way of adding a fantastic manure that produces very vibrant coloured flowers .
, x8 3/4" holes in the bottom. Run round with a 1/2" radius bit. Covered in compost now.Not sure paint will stuck to creosote?
