Erie Fred
- Erie, Pa USofA
Here's a crazy Idea....L-E-A-R-N.No that would be well beyond my ability
If our pipeline welders do x-ray quality welding downhand on pipe, then
You can stick a simple bracket on....
Been used since the dawn of time for securing loads and sheeting up, place I work at still uses them for securing loads with ratchet straps.Is this for tying down loads ?This type thing is only a rope hook , suitable for sheeting up.
Bob
Have you got a direct link to that?
Unfortunately it makes no difference. I find most car trailers such a pain for this. Why they can’t fit some actual lashing rings instead of rope hooks. For years you’ve never been able to use them to tie down.
On an ifor williams with the right size straps you can hook on the chassis rails. But it’s a pain as well.
6010/6011 is very rare in uk, and 6013/7018 is totally unsuitable for downhand.Here's a crazy Idea....L-E-A-R-N.
(1) Nothing I attach to the trailer will be formally testedRope hooks aren't any good for ratchets for three reasons.
1. They aren't load tested
2. If you put a rope on them the rope sits right near the corner meaning it would have to sheer the hook, if you attach a ratchet strap the load is applied further away from the corner increasing leverage and bending or snapping the hook.
3. To attach a ratchet strap to a rope hook people typically use the triangular hole.
I thought I had read that somewhere but wasn't sure, think is was a VOSA posting where they had pulled a trailer and they picked up that the load was secured via the rope hooks and it was a no-no
3 points if you get someone on a bad day as well. Or a day to meet the traffic commissioner if you’re really luckyYes, its quite a big fine per strap. The offence is insecure load, not sure whether they award points for that. @Pete.
Bob
I'm sure these regulations and fines relate to commercial vehicles and trailers requiring an annual mot.
Can imagine too many private motorists with a small trailer will be pulled.
Any trailer I've ever owned has welded on hooks. Never been a problem.
Any trailer I've ever owned has welded on hooks. Never been a problem.View attachment 440489
(3) I've never seen anyone do that. That's similar to saying never use rope for anything because you might not tie a proper knot. I'm not sure on the bending argument, it depends on the orientation of the hook and the load. Worst case would be one side of the strap hook tight into the corner, the side 20 or 30mm along the free leg.
Having said that it might make sense to see if i can source and fit rings at the new locations. I'm not going to cut off snd replace the existing fittings but conceivably a bar could be added to close them.
Can anyone link to the sort of fitting I should be looking for?
These are exactly what I used on my trailer. Only thing I dislike about them is the crap that get`s stuck in there like leaves, mud etchave allays used recessed trailer lashing rings, made a template up for a router that cuts the hole. and use it to line up on the chassis rails, they are rated to 500kg each and have 8 on my trailer, happily towed 3 tone dumper all the way back from Wales using them.
should only take an afternoon to fit 8 and they cost around £5-6 each, and when not using them they store nicely out the way when carrying flat loads
6013 is no problem vertical down. 6012 is better. Even 7018 is doable but not easy.6010/6011 is very rare in uk, and 6013/7018 is totally unsuitable for downhand.
