put a bung in the outlet and slightly pressurise it. not 2 much though otherwise it will blow up like a baloonI am due to make a large diesel tank from 4mm mild steel sheet next week, and wondering if there are any tips to help ensure all the welds are diesel tight! I have got plenty of leak test spray in stock! Any tips would be appreciated,
Remlap.
Is it a storage tank or a vehicle tank? Put a couple of reinforcing bars across the inside before you weld the top on if you think it might belly out. Are you using a good welder, you don't want the duty cycle to cut you out half way up a side.
who said it was a migif its a stick welder it will only run a foot at a time anyhows not that it makes any odds
It's in the mig welding section![]()
