thats exactly as I imagined it ,,,I just tried out my cold wire feeder for the first time. I was looking for a way to free up some needed worktop space that’s currently occupied by a pile of tape, twine, etc., and @tom2207 had a good suggestion for a tape storage rack design that I could install under my existing ceiling-hung shelves.
I figured that making the mounting brackets for the rack would be a good way to start experimenting with the wire feeder. This is the torch that I used.
I'll experiment with the other torch that I'm setting up (a gas-lens torch) later on, after I've gotten the hang of using the wire feeder with standard cups and collets.
After messing about with a few practice scraps...and producing some messy-looking welds...I finally came up with some settings that worked fairly well as a starting point for mild steel 1/8" butt joints. I used pieces of 2” x 1/8” bar and 1-1/2” x 1-1/2” x 1/8” angle to make the mounting brackets for the tape rack. I cleaned the metal a bit, clamped the pieces together, and tacked the joint in a couple of places on each side.
I'll admit that I cheated a little by clamping a length of angle on the workbench to serve as a guide that I could slide my torch hand along to help maintain a straight line. Even using the guide, I still had to toss out a few less-than-acceptable (read 'ugly') welds, until I found a comfortable position for holding the torch with both hands and drawing it steadily along the guide. Using both hands really helped steady the torch. After welding, I trimmed off a couple of pieces of excess metal at the ends to check the penetration of the welds, and I was pleased to see that they had full penetration (see green arrow below). Note that I didn't put much of a bevel on the edges before welding. If I had made a deeper bevel, I probably could have used somewhat less current (I used 135A) and a little faster wire feed rate, which I think could have reduced the HAZ width The pieces below are my best efforts, which I think came out pretty well.
I welded a short piece of ¾” square tube (rotated 10 degrees) onto each of the mounting brackets to insert in the ends of the long 1” square tube that the rod-holder sleeves will slide on. Then I slapped together the rod-holder sleeves, which are pieces of 1-1/4” square tube with nuts welded onto them. The rods are 3/8” x 8" bolts with the heads trimmed off. If desired, the bolts can double as set screws to secure the positions of the rod-holder sleeves on the long tube.
After reconsidering the mounting position under the shelf, I ended up slicing 1-1/2” off each of the mounting brackets, which gave me a chance to check more spots for weld penetration along the butt joints (green arrows below), which was still excellent.
Here's the finished rack, mounted under one of my ceiling-hung shelves. As you can see, I can slide the rod-mount sleeves back and forth to accommodate rolls of tape and other items with different diameters.
Now I need to wade through dozens of rolls of tape, twine, etc., and toss out any expired or otherwise unusable stuff before stocking my new tape rack.
Thanks! The feeder is a CK WF-3. Here's my post about acquiring it: https://www.mig-welding.co.uk/forum/threads/today-i-acquired.50192/post-2391402Really nice work. What feeder are you using?
You had a good idea, and I think it should work well. I'll probably start loading it up today.thats exactly as I imagined it ,,,
First the smokeWhere are the flames?![]()
Now I know the turbo won't self-destruct due to oil starvation and IED me I'm waiting on some high voltage modules aka eBay tasers and 20 KV diode to arrive to fix the ignition system then it's off to buy some kerosene so a week or twoWhere are the flames?![]()
Improvised Explosive Device
Cheers.Wow @nickk , that helical stringer is mighty impressive!!!!
A pair of staircases I finished late last year but only recently had the energy to photograph,they were testing,awkward single track lanes for a few miles,difficult access gateway and barns,first time to manipulate 50/25 solid half round,with some very tight bend returns/helixes,so took the gas and anvil with me,the treads on each are continuous folded on my trusty Morgan geared folder,discussed here previously,in 3mm plate and welded on site,at least on the helical stairs,so took the Migatronic 300 with me for the duration,another operation in itself with the digger controlling the descending tool trailer down the slope and over trenches.
All very rewarding ultimately.View attachment 439590View attachment 439591View attachment 439592View attachment 439593View attachment 439594
