winchman
- Merseyside
A Vitara with a small Suspension lift and a Lockrite rear diff locker will beat most heavily modified 4x4s.
The combination of light weight and good tyres and it should be unstoppable and all very cheaply too.
Possibly under £1000, cheaper if you can find used
www.jimnybits.com
www.jimnybits.com
Vitara Powertrax Lockright Differential Locker
For ease of install and people who are on a budget, Powertrax Lockright diff lockers are hard to beat. Of course, selectable lockers such as ARB air lockers would be much more desirable, the Lockrights get the job done for a fraction of the cost. These lockers will lock up the rear axle when...
215 75 15 INSA SAHARA 2 MUD TERRAIN TYRES ONLY X4 SPECIAL OFFER!!! | eBay
4X INSA SAHARA 215 75 15. TYRES ONLY RIM SHOWN FOR DEMONSTRATION PURPOSES ONLY. 4X TYRES ONLY.
www.ebay.co.uk
1.5" / 38mm Suzuki Vitara Lift Kit
This lift kit is ideal for lifting the Vitara without the expensive of a full blown spring lift kit The kit comes with the following: 4x 1.5" lift coil shaped lift spacers in black +1.5" front strut spacer brackets for lowering your front suspension travel for more articulation Front...
