DAPPH
as dyslexik as I'm daft
Think we ought to have a tread about Bodges we have done or discovered especially safety related ones .
i kick off with a 400 mm or so bench saw & fence , modified by some " Clever Dikky ".
The heavy duty 16 amp motor would not allow the blade to return to the vertical (my investigation on Wednesday ) so they used five strong black nylon cable ties through a drilled hole in the skirt edge of the table top to pull it up almost vertical . The rise 7 fall is jammed solid at max height so this might eb the problem.
The fence mount was made from chip board and some sort of aluminium U shaped channel with flat head furniture bolt resting on the table bed so the fence inclines 8 mm or more upwards at the middle of the blade .
Taking it apart was interesting , things didn't feel right on the blind side of the bed . Getting two guys help me to turn the table upside down over two stout planks I was highly amused to see that the two 8mm bolts used to attach the chipboard fence guide were in fact stainless steel studding split for 10 mm down the middle and splayed out with a screwdriver , then a correct sized washer slipped over the unsplayed end and tightener with mole grips and a spanner'd proper nut on the chip board side
In all my 60 or so years of messing around as an amateur or professional electro mechanical engineer I've never come across that sort of bodge before .
