Or rebuild, as now that I've actually had a proper look at it, it's in worse condition than I thought it was.
I had wondered why it had split along where the bracing is welded on the back, but I didn't realise that the lower edge of the bracing is completely worn/torn away, with nothing actually supporting the edging-
And yes, the edging has a bow in it, but can be pushed back straight by hand, so it just needs suitable support welded back in.
In the past I've had to use 7018 rods on the bucket, as the normal MIG wire just splatters everywhere, but I think I'm going to have to buy some suitable MIG wire.
I tacked the bucket edge back on earlier, but the gaps are just going to be too big to weld up with rods. Even with the edge pushed back to where it should be, with the edge lined up with the other part of the bucket, it was still a few mm away from the side of the bucket due to wear at it's closest point. At the furthest away point it was over 10mm.
I'm thinking 6mm (or possibly 8mm) Hardox to recreate the lower support, and bash the remains of the vertical part of the support back down to meet it as best as I can.
However even with that, it's probably £4-600 in materials alone, along with lots of time cleaning and chasing the various cracks.
And a quick google hasn't revealed any similar 4 in 1 buckets currently for sale. There's a few for older 3Cs, and one for an early 3CX Sitemaster, but it looks a lighter construction.
