W.olly
- Radcliffe, Manchester
I have been looking around for a half decent trolley jack. I am getting a C3 Corvette soon and have a Shogun also. so as the Vette has a ground clearance of 109mm and Shogun a lot more. Inbetween we ave a Citroen DS3 aswell.
I want a minimum of 500m lift but low enough to get under the Vette, Then i saw this
www.sealey.co.uk
Looks a good bit of kit and has a huge 770mm lift for 3 ton. But close to the Vette ground clearance as minimum saddle height is 98mm, 10mm clear. If i am seeing it right that is with ground clearances and saddle heights. .
It would come in for the stands i ave planned for the Vette aswell while working on it to get it up to the height
So what are your thoughts on Sealey gear, mainly this jack as i cant seem to find many reviews unless it new out. and what other trolley are about with similar spec for a budget of £300.
I thought of a more standard jack and make my own extra lift tube for the saddle to get the extra lift, but then thought best not to for some reason.
2/3tonne Low Entry/High Lift Trolley Jack | 32000LEHL | Sealey
1 Year Guarantee - Three Trolley Jacks in one, the lifting span is quickly & easily adjusted. A low entry, high lift & super high lift in one Trolley Jack.
