There is absolutely no way you've got the necessary precision for the required clearance between individual punch and die with that set up for a clean, burr free, cut, never mind for all those together.
I'm not near the info I need at the moment, but when I get into work, if I remember, I will have a rummage for the supplier of punch and dies of very similar size that I used on a machine I designed a few years ago that is bashing out a few hundred thousand holes per set before the punch and die need re-grinding. Their website has all the info you need for clearances etc - and if I remember correctly, the price per punch/die was small enough for it simply not to be worth making your own.
) lot closer than I was last week.
