Could anyone give me some advice please?
I am new to welding and started off last year with a Sealey Mighty Mig 100 which gave me a taste for welding which I have found very satisfying. However, my welds leave a bit to be desired so have upgraded to a better machine which I have now purchased.
Before starting to use this BRAND NEW machine supplied by the agent, I looked through the operating instructions including the specification and noted that has an input amperage of 30.9amps.
This caused me concern as it is fitted with a 13amp plug and on removing the fuse have found that the fuse has been bridged with a piece of wire (not fuse wire) - see attached image.
Having found this I then looked at the specification for the input supply cable (see attached image) and from the identification markings was able to establish that the manufacturers specification for the cable is 20amp.
From your experience, would you consider it safe to use as it seems to me that it will over load the electrical supply and will be a fire hazard.
To my mind, this welder should be fitted with a 32amp plug and a cable from the plug to the machine also rated at 32amp.
I have contacted the supplier who says that these machines should be fitted with a 20amp fuse but this would be 50% more than the 13amp UK plug is designed and certified for.
Given the questionable supply gives me concern regarding the quality and functionality of the internal parts.
Your thoughts please.
