Sergei Slovenija
- Slovenija Ljubljana
Tig brazed, turned and knurled? What do you mean by rolling mesh?First experience in rolling mesh. TIG brazing of bronze to steel. Prototype.
View attachment 433081 View attachment 433082 View attachment 433083 View attachment 433084
Let me rephrase - knurling with helical rollers on a lathe... After brazing.Tig brazed, turned and knurled? What do you mean by rolling mesh?
?I started in tailstock, chuck pushed out the taper..
I suspect it is meant to be pulled as in the chuck was pulled out of the tailstock taper.
I am starting to dislike the ferrex bandsaw,
Of course. My brains a bit foggy, only just got upI suspect it is meant to be pulled as in the chuck was pulled out of the tailstock taper.
Nothing adjustable on ferrex. Its an awkward shape with the blade at an angle which doesnt seem to match up with the flat top, theres no sighting lines to aim it with.Blade's tension / rollers or the adjustable thickness guide is usually the reason on my cheapy (not Ferrex).
Do you make this stuff on a CNC mill or CNC Router?
On the Chiron I retrofitted.Do you make this stuff on a CNC mill or CNC Router?
I thought you had a mega machine.On the Chiron I retrofitted.
Does you make and sell such things to others to….
I have sold a few different parts, this particular one is heading to Aruba with a couple of other bits.Does you make and sell such things to others to….
