Aha... Is that a BSA C.15T that I see there ?I use heat lamps I picked up from Mole Valley. theyre 175w bulbs. I just use the ones where I’m working. Been meaning to check that they don’t damage your eyes! Makes good lighting too.
Sure is! You’ve got a sharp eye!Aha... Is that a BSA C.15T that I see there ?
Well done, that fellow....
How many people die of CO poisoning each year from using those heaters ?Another vote for IR heaters.
Any butane or propane heater produces about one and a half times the volume of water, as what is in the cylinder, so for a workshop I wouldn't have one, and thats even before the issue of CO poisoning.
I have a gas hob in my kitchen, I’ve not died yet.How many people die of CO poisoning each year from using those heaters ?
Not a using gas grill inside, not a torpedo heater, not a makeshift set-up.
Mine have a CO detector that shut's them off.
You could buy and install a ceiling mounted CO detector for under $30.
Not a hob but the boiler. When I was about 16 the council house/hovel we had to live in had a badly installed and non maintained boiler that nearly killed us all. We all felt sleepy and sick me and my sister were on the sofa half asleep when my mum realised something was wrong and got us out the house.I have a gas hob in my kitchen, I’ve not died yet.
Got a hot B.40GB engine in mine..... twin plugged it last year, amongst other things....Sure is! You’ve got a sharp eye!
Funnily enough - I spoke to a neighbour for the first time in ages 2 days ago.As @Farside says direct IR heating is most 'efficient', but not helpful if you are moving around the space.
An air to air heat pump has a CoP of 3-4 so as cheap to run as gas.
Easy enough to install if you are vaguely handy. Cools in summer too!
For example:
Lux Air Air Conditioning / Heat Pump Inverter System 9000BTU 2.5KW 20m² Area
Introducing our new range of Luxury Air Conditioning, featuring high output UV-C lamps to sterilize the air. This market leading air conditioning unit features the highest specification ever seen! All new systems coming summer 2022 offering air purity and air conditioning in 1 unit! Utilizing...www.diy.com![]()
electriQ Easy-Fit 9000 BTU A++ WiFi Smart Wall Mounted Air Conditioner with Heat Pump - 4m Pipe Kit Included eIQ-9WMINV | Appliances Direct
Buy electriQ Easy-Fit 9000 BTU A++ WiFi Smart Wall Mounted Air Conditioner with Heat Pump - 4m Pipe Kit Included eIQ-9WMINV from Appliances Direct - the UK's leading online appliance specialistwww.appliancesdirect.co.uk
it still goes on there own service people past my boiler when it should have failedCouncil didn't give a monkeys.
Imagine that these days!
I dread any of my neighbours getting one installed, the great roaring noise they make when working would be pretty offensive at night in my quiet little village, especially if next door. I sleep with the outside door to my (bungalow) bedroom open at night, all year round, and it’s totally silent outside most nights.Funnily enough - I spoke to a neighbour for the first time in ages 2 days ago.
He's retired, & has recently had his heating "upgraded" to a system with an Air Source Heat Pump.
Another neighbour with us asked "is it any good?" - & he replied that it was rubbish, & he wished it had never been fitted.
(Like lots of this stuff - maybe it works OK I a super-insulated home - but in a 1970's- built ex-council semi??)
you cant do that in my area the foxes and cats would be in your house far quicker than you might thinkI dread any of my neighbours getting one installed, the great roaring noise they make when working would be pretty offensive at night in my quiet little village, especially if next door. I sleep with the outside door to my (bungalow) bedroom open at night, all year round, and it’s totally silent outside most nights.
though arnt you getting a little old here if your already moaning about a small fan spinning up compared to what you are doing in your shed as the neighbours could already be moaning about you
yet your moaning about a small fan spinning up, you should try freezer vehicles that have a loud deep drone on them really annoying
then thats an industrial fan not a little diesel fan spinning upBut I don’t work in the workshop all night long.
And it’s not a ‘little fan’, it’s a loud whirring fan about 24” diameter that I can hear 50 yards down the road when I walk around the village and see the two houses that already have them installed.
