Hi,
Would anyone care to make a guess, whether this regulator would fit SGS, Hobbyweld, or either. I'm thinking not just the coupling, but whether the guages will clear the guards arount the top of the cylinder. I've seen others where the guages are at 90 degrees so stick right out, but the sort I link would be neater (if it fits)
static-arc.myshopify.com
GAS BOTTLE PRESSURE FLOW REGULATOR DUAL GAUGE ARGON CO2 NITROGEN MIG TIG WELDING
STATIC ARC WELDING SUPPLIES, MIG TIG MMA ARC WELDERS FILLER RODS ELECTRODES WIRE TUNGSTEN CONSUMABLES MB15 MASK HELMET GLOVES CLAMPS TORCH 14AK PLASMA CUTTER PT31 GAS REGULATOR GASLESS FLUX WIRE FEED ROLLER CABLE ANGLE GRINDER BENCH SANDER JIGSAW DRILL POLISHER STEEL FLAT ROUND SQUARE ANGLE BARS...
