Agreed - water on the floor before hand to suppress the dust.It only happens if you don't know how to use one.
Next the the manufacture and sale of brooms should be banned.
using a broom causes massive dust disturbance which in turn causes huge secondary exposure
The two situations aren’t comparable
I fully support prohibiting brooms
using water is a myth, it doesn’t workOnly if you're dry sweeping Parm. My point is that a blanket ban is not appropriate as control measures. In many situations the broom is the most appropriate tool it's the process that needs to be managed. We got mini dust busters and all sorts of things nowadays for controlling exposure.
that makes no oddsIs that before or after you put the 25kg sack of kiln dried through the pressure pot?![]()
i have a woodchip extracta on my sealed cabinet and open blasting have an airfed blasting helmet
Thankyou to somebody that obviously has swept floors.....It works as a control measure. It might not remove 100% of all dust but it certainly reduces the airborne element. Any amount of the dust that's wet will not go airborne.
I’ll show you what happens with a dust lamp. It leaves a finely suspended aerosol that remains suspended in the air for a very long timeIt works as a control measure. It might not remove 100% of all dust but it certainly reduces the airborne element. Any amount of the dust that's wet will not go airborne.
My brother used the same trick when he had a job selling hoovers.
wasnt kirby cleaners was itpressurising gullible punters and relieving them of about 600 quid
