nothing apart from looking a bit krap when the beaks are the same heightI've never been lucky enough to have an anvil - but what's wrong with flattening the top ?
He destroyed the hardened layer from the face of the anvil. This is repaired with a heat-treated faceplate, secured via an expandable horizontal wedge.I've never been lucky enough to have an anvil - but what's wrong with flattening the top ?
the amount of wear would have been through it anyhow if it was hardened so no loss . i have an old one well worn and the angle grinder wont even look at itHe destroyed the hardened layer from the face of the anvil. This is repaired with a heat-treated faceplate, secured via an expandable horizontal wedge.
YouTube is full of videos of similar “restorations”. It's like the Olympic Games to see who can destroy the biggest anvil. This view shows an anvil-corpse. But she didn't get any better.the amount of wear would have been through it anyhow if it was hardened so no loss
I have an old anvil which is in a poor state, will 7018s be good enough to build the top face back up for refacing? I have seen a few youtube videos and guys are welding the face up, I think one gave it a heat treatment then after which I wont be able to do, its on my to do list at some point if I get a way ahead,We just build them up with 7018 when they get that bad
How was a steel plate welded to cast iron?depends on the anvil sergei.
Over here we used to have an iron cast base with a piece of hardened steel fire welded to the top.
The piece that was fire welded on top was regularly ⅝" thick.
In them cases there is no problem milling or grinding the anvil down
I once listened to a lecture about what kind of anvils were used since the Copper Age. Making the first iron anvil weighing at least 20 kg was a real feat + gathering several experienced blacksmiths and hammerers in one place. Before the advent of water wheel-driven hammers, the anvil was shaped like a very large “nail” with a large head weighing several kilograms. That did not stop the blacksmiths from forging quite large objects. For massiveness, a "nail" was inserted into a hole in the stone, increasing countermass and overall rigidity. Anvils in ancient times were always expensive and were a coveted trophy in war.I think Brad was being casual with the phrasing saying "iron, cast" and not "cast iron". Clearly a typical full size blacksmith anvil is going to have a cast steel body, typically assembled from rough castings forge welded to form the anvil shape before the top plate is also forge welded on top.
I worked on archaeological expeditions with truly mass-produced cast iron products (boilers, oven doors). Manufactured no later than 1230. This cast iron was as fragile then as it is now.Fire welded
Forge Welded
Steel plate and freshly cast anvil heated in a forge to sparkling heat, steel plate hammered or pressed onto the anvil.
And when i say cast iron - it won't be meehanite or SG iron. It will basically be a pig iron, more or less a wrought alloy.
