gaz1
- westyorkshire
i would have used a slide garage door to the side but you need tracks both top and bottem and its in the way with an up and over doorI’m almost at the point of proceeding with insulating my garage, primarily to cut down on noise transmission.
The ceiling will be acoustic plaster board and rockwool in either scenario. I will also build a movable wall behind the door.
Thoughts?
anything that you build will have to be at rear of the door opener you could build a frame under the slider of the up and over door and slide it to the sides or have it with openers
but thats going to be under the sliders you wont know until its fitted
