slim_boy_fat
- Scottish Highlands
"Modem" ... Forsooth! Verily which Millennia art thou computing from !![]()
I suppose I should have referred to it as "the router", but the folk at the ISP understood fine. "Modem" ... Forsooth! Verily which Millennia art thou computing from !![]()
I suppose I should have referred to it as "the router", but the folk at the ISP understood fine. How old is the Heater?It lives!! My modem chose to self destruct late afternoon so been interweb-less until today [replacement only arrived today despite ISPs promises [but that's for another thread....]
Sat a.m. I cleaned the entrails and bled the system and it eventually fired up and is back to full strength.
Appreciate all the responses/suggestions- happiness reigns again at Slim Towers!!
How many hours a week roughly is it ran?
What fuel do you use?
It seems strange that one would need disassembled and cleaned out internally.
I've read mention from various sources that plain kero should really be dosed with a bit of oil to keep the pumps happy.Another update. The two latest pumps, which are a different brand, have also failed. So that's six pumps dead now. I ditched the kerosene and put in fresh pump diesel and the heaters have been going a week now. The kero was very old, reclaimed from a decommissioned tank. It had been properly filtered and I was told it would be fine. Guess not. It's nice to have a warm workshop again.
Is the power supply common to both pumps? If so I'd be taking a look at that incase it's over or under supplying them.Another update. The two latest pumps, which are a different brand, have also failed. So that's six pumps dead now. I ditched the kerosene and put in fresh pump diesel and the heaters have been going a week now. The kero was very old, reclaimed from a decommissioned tank. It had been properly filtered and I was told it would be fine. Guess not. It's nice to have a warm workshop again.
The pumps obviously vary.FWIW I run my China heater on pure Kero and it runs for 10 hours at a time with no issues at all.
One thing not mentioned so far is that if the cap on the fuel tank is not breathing you can develop a partial vacuum in the tank as the fuel is consumed , once it gets to the trip point you heater won't work.It's not as simple as that I'm afraid.
We are referring to a case of repeated pump failure. The causes can be for example:
Wrong ID fuel pipe or pipe collapse/ kink
Dirty or clogged pipe up tube/ filter
Poor fuel quality or other fuel contamination
Overvoltage or other current supply to pumps
I think the actual fuel itself plays a small part in it to be honest.
