Nomad
- North Devon (for how long?)
I'm looking for a compressor for occasional DIY use, mainly to spray a couple of project cars.
I already have a couple of HVLP guns, work will be 1 full respray + roof resprays on a couple of others.
My spraygun spec says 3 bar, 7-12cfm ( 200-340 liters/min), I guess this is for spraying different paints / viscosity / temps etc.
Will a compressor at the lower end be ok or do I need something that can deliver the higher end?
My guess is I'll be spraying a section - then pausing before I do the next section - so the compressor won't be running continiously.
Looking at a couple of links in the sticky thread they talk about the duty cycle - but the adverts I'm seeing don't list this
www.about-air-compressors.com
The smaller 25 litre air tank will be easier for me to store, will I regret not getting a 50 or 100 litre tank?
I can get a 2HP / 24 litre compressor locally, spec 8 bar max, 8 cfm. Will it do what I need?
There's quite a jump in price if I want anything that will deliver 12cfm.
Other uses will be :
Inflate a couple of pressure vessels (air tanks for a water system, volume 100 litres, pressure 3 bar)
Blow up car tyres occasionally (40 psi max)
Any & all advice appreciated
What Size Air Compressor for Spray Painting?
If you have a spray gun or you're looking to purchase one for a painting project at home or in the workshop, you may now be wondering what size air compressor you need to run your spray gun.
