No idea. It was just a buckshee bit of bar, I thought it was plain old MS until the drill bounced off it.What heat treatment is it ?
Also it does work harden IIRC so no rubbing, cut it or don't.
Haven't heard that word in a while!buckshee
I have some 4140 bar about 30/32mm diameter here; was planning to use it to make a pivot boss for my tyre changer (in the 'duck's head' thread) but although I cut a length off with a slitting disc and could take a skim cut off it, I couldn't get the bloody lathe centre drill to do more than tickle it!
At that point I didn't know what it was so I took it into work and PMI'd it: something like 0.8% Cr. It feels really heavy for its size as well, odd.
Uhm no, you specifically stated it was "4140 bar"No idea. It was just a buckshee bit of bar, I thought it was plain old MS until the drill bounced off it.
Ended up ordering a 50mm long sample of FCMS from an ebay seller - just to make a pivot boss! Turned most of it to swarf and fitted oilite bushes in it.
They stated in the first post that they thought it was mild until they tried to drill it, at which point the centre drill barely touched it so they took it to work to test and found it to be 4140.Uhm no, you specifically stated it was "4140 bar"
And now you plead the 5th ?....
"I thought it was plain old MS"
Thanks. Saves me the bother.They stated in the first post that they thought it was mild until they tried to drill it, at which point the centre drill barely touched it so they took it to work to test and found it to be 4140.
You do seem to jump to argumentative very quickly on these posts!
