Gearbox to engine, car wheel nuts etc. I will assume the bolts of HGVs and buses can work lose? I've seen them plastic pointers that are fitted to each wheel to flag movement.
I think if they really needed them, they would simply make them captive on the fastener.As @PhillipM says its down to cost but also simplicity. It's not uncommon these days to have "special" bolts where a large bolt has a smaller head on it. For some reason they may need a thicker shanked bolt but not done up to a silly torque (or for example if it's going into aluminium). That way the monkey assembling the car doesn't need to know that this 16mm bolt needs torque a and this 16mm bolt needs torque b. 16mm socket means torque a and 14mm socket means torque b.
I think it was on the JLR production line where I saw that torque wrenches had the sockets permanently fixed to them and were fixed at a specific torque. Different head size equalled different torque. Having to add a nord lock into the mix just complicates matters.
I worked with an engineer that came from a large diesel engine manuf.You're all over thinking this.
I sometimes get clients on boats phoning up as thé have 'vibrations'.
First question, 'are they good or bad vibrations ' then start humming the beach boys.
Quite permanent…..far easier just to use a ball pain hammer on the threads!Dab of weld on the end. Problem solved?![]()
